소개
Removing the front case is easy, just be careful when you take it off.
필요한 것
Insert the plastic opening tool in between the front case and the back case.
Apply downward pressure to make the case lift upwards, thus popping the front case off.
거의 끝나갑니다!
To reassemble your device, follow these instructions in reverse.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
