주요 콘텐츠로 건너뛰기
Sony Ericsson W200i Keypad Replacement
필요한 것
  1. Sony Ericsson W200i Keypad Replacement, Disassembling Sony Ericsson W200i Battery: 1 단계, 이미지 1/2 Sony Ericsson W200i Keypad Replacement, Disassembling Sony Ericsson W200i Battery: 1 단계, 이미지 2/2
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i Keypad Replacement: 2 단계, 이미지 1/2 Sony Ericsson W200i Keypad Replacement: 2 단계, 이미지 2/2
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i Keypad Replacement, Front Case: 3 단계, 이미지 1/3 Sony Ericsson W200i Keypad Replacement, Front Case: 3 단계, 이미지 2/3 Sony Ericsson W200i Keypad Replacement, Front Case: 3 단계, 이미지 3/3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i Keypad Replacement, Keypad: 4 단계, 이미지 1/2 Sony Ericsson W200i Keypad Replacement, Keypad: 4 단계, 이미지 2/2
    • Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Nestor Trevino
회원 가입일: 01/14/11
209 평판
안내서 1개 작성함
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 회원
CPSU-FORTE-W11S14G10
5 회원들
안내서 16개 작성하였습니다
댓글 한 개
Can you guys tell me where i do get parts for these legacy phones?My jostick died on this phone.Not working at all i only can use the keypad.
Janos Lazar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 5,508
