주요 콘텐츠로 건너뛰기
Sony Ericsson W300i Camera Replacement
필요한 것
  1. Sony Ericsson W300i Camera  Replacement, Camera: 1 단계, 이미지 1/2 Sony Ericsson W300i Camera  Replacement, Camera: 1 단계, 이미지 2/2
    • The tools you will need for this step is the prying tool and the T6 Torx screwdriver.
  2. Sony Ericsson W300i Camera  Replacement: 2 단계, 이미지 1/3 Sony Ericsson W300i Camera  Replacement: 2 단계, 이미지 2/3 Sony Ericsson W300i Camera  Replacement: 2 단계, 이미지 3/3
    • Remove the back cover of the phone by pushing downwards with your thumbs.
  3. Sony Ericsson W300i Camera  Replacement: 3 단계, 이미지 1/2 Sony Ericsson W300i Camera  Replacement: 3 단계, 이미지 2/2
    • Now, remove the battery from the phone by gently prying the battery out.
  4. Sony Ericsson W300i Camera  Replacement: 4 단계, 이미지 1/2 Sony Ericsson W300i Camera  Replacement: 4 단계, 이미지 2/2
    • Remove the front plate from the phone by using the prying tool.
  5. Sony Ericsson W300i Camera  Replacement: 5 단계, 이미지 1/2 Sony Ericsson W300i Camera  Replacement: 5 단계, 이미지 2/2
    • You now have access to the fours screws that hold the front of the phone together. Remove the four screws.
  6. Sony Ericsson W300i Camera  Replacement: 6 단계, 이미지 1/2 Sony Ericsson W300i Camera  Replacement: 6 단계, 이미지 2/2
    • Use the prying tool to separate the two parts of the top of the phone
  7. Sony Ericsson W300i Camera  Replacement: 7 단계, 이미지 1/3 Sony Ericsson W300i Camera  Replacement: 7 단계, 이미지 2/3 Sony Ericsson W300i Camera  Replacement: 7 단계, 이미지 3/3
    • Use your fingers to remove the screen and unplug the ribbon cable from the bottom right corner of the back of the screen.
  8. Sony Ericsson W300i Camera  Replacement: 8 단계, 이미지 1/2 Sony Ericsson W300i Camera  Replacement: 8 단계, 이미지 2/2
    • Now you have access to the camera, which is the silver plate at the bottom of the phone. Remove the camera and replace with a new camera.
결론
Laura Inbody
회원 가입일: 02/19/16
7 평판
안내서 1개 작성함
Ohio State, Team 1-2, Garvin Spring 2016 Ohio State, Team 1-2, Garvin Spring 2016 회원
OSU-GARVIN-S16S1G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 338
