주요 콘텐츠로 건너뛰기
Sony Ericsson W350a Memory Card Replacement
필요한 것
  1. Sony Ericsson W350a Memory Card Replacement, Battery: 1 단계, 이미지 1/2 Sony Ericsson W350a Memory Card Replacement, Battery: 1 단계, 이미지 2/2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  2. Sony Ericsson W350a Memory Card Replacement: 2 단계, 이미지 1/3 Sony Ericsson W350a Memory Card Replacement: 2 단계, 이미지 2/3 Sony Ericsson W350a Memory Card Replacement: 2 단계, 이미지 3/3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  3. Sony Ericsson W350a Memory Card Replacement, Memory Card: 3 단계, 이미지 1/1
    • After removing the battery, insert the memory card into the lower left slot as designated by the circle in the picture. Be sure to have the contacts aligned into their appropriate slots.
결론
Parker Stroble
회원 가입일: 03/09/12
86 평판
안내서 3개 작성하였습니다
Clemson, Team 1-4, Benson Spring 2012 Clemson, Team 1-4, Benson Spring 2012 회원
CLEM-BENSON-S12S1G4
4 회원들
안내서 14개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,154
