주요 콘텐츠로 건너뛰기
Sony Ericsson W350a SIM Card Replacement
필요한 것
  1. Sony Ericsson W350a SIM Card Replacement, Battery: 1 단계, 이미지 1/2 Sony Ericsson W350a SIM Card Replacement, Battery: 1 단계, 이미지 2/2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  2. Sony Ericsson W350a SIM Card Replacement: 2 단계, 이미지 1/3 Sony Ericsson W350a SIM Card Replacement: 2 단계, 이미지 2/3 Sony Ericsson W350a SIM Card Replacement: 2 단계, 이미지 3/3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  3. Sony Ericsson W350a SIM Card Replacement, SIM Card: 3 단계, 이미지 1/1
    • Slide the SIM card into the lower right slot identified by the circle in the picture, ensuring the contacts are aligned properly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Parker Stroble
회원 가입일: 03/09/12
86 평판
안내서 3개 작성하였습니다
Clemson, Team 1-4, Benson Spring 2012 Clemson, Team 1-4, Benson Spring 2012 회원
CLEM-BENSON-S12S1G4
4 회원들
안내서 14개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 912
