주요 콘텐츠로 건너뛰기
Sony Ericsson W350a Speaker Replacement
필요한 것
  1. Sony Ericsson W350a Speaker Replacement, Battery: 1 단계, 이미지 1/2 Sony Ericsson W350a Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  2. Sony Ericsson W350a Speaker Replacement: 2 단계, 이미지 1/3 Sony Ericsson W350a Speaker Replacement: 2 단계, 이미지 2/3 Sony Ericsson W350a Speaker Replacement: 2 단계, 이미지 3/3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  3. Sony Ericsson W350a Speaker Replacement, Speaker: 3 단계, 이미지 1/2 Sony Ericsson W350a Speaker Replacement, Speaker: 3 단계, 이미지 2/2
    • Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
    • Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
  4. Sony Ericsson W350a Speaker Replacement: 4 단계, 이미지 1/1
    • Using a mini Phillips screwdriver, remove two screws by turning them counterclockwise.
  5. Sony Ericsson W350a Speaker Replacement: 5 단계, 이미지 1/1
    • Insert an opening tool in the bottom crack between the front and back plates and use a gentle upward pull to separate the back case from the front case.
    • Side buttons/controls may fall from their place in between the back and front casings.
  6. Sony Ericsson W350a Speaker Replacement: 6 단계, 이미지 1/1
    • Using a T5 screwdriver, remove the two screws by turning them counterclockwise.
  7. Sony Ericsson W350a Speaker Replacement: 7 단계, 이미지 1/2 Sony Ericsson W350a Speaker Replacement: 7 단계, 이미지 2/2
    • Using an opening tool and a gentle outward motion, separate the front plate from the inner phone workings.
  8. Sony Ericsson W350a Speaker Replacement: 8 단계, 이미지 1/2 Sony Ericsson W350a Speaker Replacement: 8 단계, 이미지 2/2
    • Using a Phillips head screwdriver, remove the screw from the front number pad by turning it counterclockwise.
    • Remove the speaker from the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ldellos
회원 가입일: 03/12/12
112 평판
안내서 3개 작성하였습니다
Clemson, Team 1-4, Benson Spring 2012 Clemson, Team 1-4, Benson Spring 2012 회원
CLEM-BENSON-S12S1G4
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,021
