주요 콘텐츠로 건너뛰기
Sony Ericsson W580i LCD Replacement
필요한 것
  1. Sony Ericsson W580i LCD Replacement, Front Cover: 1 단계, 이미지 1/2 Sony Ericsson W580i LCD Replacement, Front Cover: 1 단계, 이미지 2/2
    • Insert the edge of an opening tool between the front cover and the phone.
    • Gently pry off the front cover working your way around the edges.
  2. Sony Ericsson W580i LCD Replacement: 2 단계, 이미지 1/2 Sony Ericsson W580i LCD Replacement: 2 단계, 이미지 2/2
    • Pull the front cover down and away from the phone.
    • The front keypads might come off with the front cover. Do not lose these.
  3. Sony Ericsson W580i LCD Replacement: 3 단계, 이미지 1/1
    • Gently peel the keypad away from the phone.
  4. Sony Ericsson W580i LCD Replacement, LCD: 4 단계, 이미지 1/2 Sony Ericsson W580i LCD Replacement, LCD: 4 단계, 이미지 2/2
    • Insert a spudger between the lower edge of the screen and the phone.
    • Pry the screen up to disconnect the tabs on each side holding the screen in.
    • Do not remove the screen yet. There is a ribbon connecting the screen to the motherboard.
  5. Sony Ericsson W580i LCD Replacement: 5 단계, 이미지 1/2 Sony Ericsson W580i LCD Replacement: 5 단계, 이미지 2/2
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Lift the screen away from the phone
결론
다른 6명이 해당 안내서를 완성하였습니다.
Diego
회원 가입일: 10/09/11
388 평판
안내서 4개 작성하였습니다
Cal Poly, Team 5-31, Amido Fall 2011 Cal Poly, Team 5-31, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G31
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 11
전체 시간: 5,616
