소개
Use this guide to remove or replace your SIM card.
필요한 것
Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
The panel will slide down about 2mm.
Lift the panel away from the phone.
Locate the SIM card slot.
Use a spudger to release the SIM card by pushing it in slightly until you feel a "click."
Release pressure from the SIM card. The SIM card will pop out about 5mm.
다른 2명이 해당 안내서를 완성하였습니다.
