주요 콘텐츠로 건너뛰기
Sony Ericsson W810I Battery Replacement
  1. Sony Ericsson W810I Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
  2. Sony Ericsson W810I Battery Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
  3. Sony Ericsson W810I Battery Replacement: 3 단계, 이미지 1/2 Sony Ericsson W810I Battery Replacement: 3 단계, 이미지 2/2
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lucy Bowen
회원 가입일: 09/01/11
449 평판
안내서 7개 작성하였습니다
Cuesta, Team 1-7, Zipperian Fall 2011 Cuesta, Team 1-7, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G7
1 회원
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 26
전체 시간: 7,456
