주요 콘텐츠로 건너뛰기
Sony Ericsson W810I Camera Lens Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Sony Ericsson W810I Camera Lens Replacement, Camera Lens: 1 단계, 이미지 1/1
    • Ensure the phone is switched off. Then press down firmly against the Cingular icon with your thumb.
    • Slide the panel down and remove the latch
  2. Sony Ericsson W810I Camera Lens Replacement: 2 단계, 이미지 1/2 Sony Ericsson W810I Camera Lens Replacement: 2 단계, 이미지 2/2
    • Lift the battery with your fingers and pull it out of the casing.
    • Remove the SIM card as well if you have one
  3. Sony Ericsson W810I Camera Lens Replacement: 3 단계, 이미지 1/1
    • Remove the two outer screws using a T7 Torx screwdriver.
  4. Sony Ericsson W810I Camera Lens Replacement: 4 단계, 이미지 1/1
    • Remove the two smaller inner screws with the Mini-Phillips screwdriver.
  5. Sony Ericsson W810I Camera Lens Replacement: 5 단계, 이미지 1/2 Sony Ericsson W810I Camera Lens Replacement: 5 단계, 이미지 2/2
    • Remove the back faceplate on the camera side with the blue hand wedge.
  6. Sony Ericsson W810I Camera Lens Replacement: 6 단계, 이미지 1/3 Sony Ericsson W810I Camera Lens Replacement: 6 단계, 이미지 2/3 Sony Ericsson W810I Camera Lens Replacement: 6 단계, 이미지 3/3
    • Flip the phone over and pry off the front faceplate using multiple blue hand-wedges.
    • Separate the keypad from the logic board by turning it upside down and allowing it to fall into your hand.
  7. Sony Ericsson W810I Camera Lens Replacement: 7 단계, 이미지 1/1
    • Remove the two remaining screws at the top corners of the phone.
  8. Sony Ericsson W810I Camera Lens Replacement: 8 단계, 이미지 1/1
    • Remove the logic board with multiple blue hand-wedges. Prise the logic board away carefully to avoid damaging it or snapping the wiring.
  9. Sony Ericsson W810I Camera Lens Replacement: 9 단계, 이미지 1/1
    • From the inside of the panel, press down on the camera lens to pop it out of its mounting.
    • Replace the lens and reverse the process to reassemble the device.
결론
Ben Micucci
회원 가입일: 10/14/11
186 평판
안내서 5개 작성하였습니다
James Madison, Team 2-2, Allen Fall 2011 James Madison, Team 2-2, Allen Fall 2011 회원
JMU-ALLEN-F11S2G2
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,412
