주요 콘텐츠로 건너뛰기
Sony Ericsson W810I Charger Adapter Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Sony Ericsson W810I Charger Adapter Replacement, Charger Adapter: 1 단계, 이미지 1/1
    • Power the phone off.
    • Press down firmly against the icon on the lower rear panel with your thumb.
    • Slide the panel down to remove it.
  2. Sony Ericsson W810I Charger Adapter Replacement: 2 단계, 이미지 1/2 Sony Ericsson W810I Charger Adapter Replacement: 2 단계, 이미지 2/2
    • Lift the battery and pull it out.
    • Remove the SIM card too if you have one.
  3. Sony Ericsson W810I Charger Adapter Replacement: 3 단계, 이미지 1/2 Sony Ericsson W810I Charger Adapter Replacement: 3 단계, 이미지 2/2
    • Remove the following screws:
    • Two T7 Torx screws
    • Two Phillips #00 screws
  4. Sony Ericsson W810I Charger Adapter Replacement: 4 단계, 이미지 1/2 Sony Ericsson W810I Charger Adapter Replacement: 4 단계, 이미지 2/2
    • Use an opening tool to remove the camera faceplate.
    • Be careful to not bend the camera faceplate when removing it.
  5. Sony Ericsson W810I Charger Adapter Replacement: 5 단계, 이미지 1/3 Sony Ericsson W810I Charger Adapter Replacement: 5 단계, 이미지 2/3 Sony Ericsson W810I Charger Adapter Replacement: 5 단계, 이미지 3/3
    • Flip the phone over and use an opening tool to pry off the number pad.
    • Separate the keypad from the motherboard.
  6. Sony Ericsson W810I Charger Adapter Replacement: 6 단계, 이미지 1/1
    • Remove two T6 Torx screws that secure the motherboard.
    • Use an opening tool to remove the motherboard. Pay attention to cables on the motherboard.
    • Do not pry too hard on the motherboard, as it can break under too much force.
  7. Sony Ericsson W810I Charger Adapter Replacement: 7 단계, 이미지 1/1
    • Pull off charger adapter and remove it.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ben Micucci
회원 가입일: 10/14/11
186 평판
안내서 5개 작성하였습니다
James Madison, Team 2-2, Allen Fall 2011 James Madison, Team 2-2, Allen Fall 2011 회원
JMU-ALLEN-F11S2G2
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,620
