주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Sony Ericsson W810I Key Pad Replacement
필요한 것
  1. Sony Ericsson W810I Key Pad Replacement, Battery: 1 단계, 이미지 1/1
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
  2. Sony Ericsson W810I Key Pad Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
  3. Sony Ericsson W810I Key Pad Replacement: 3 단계, 이미지 1/2 Sony Ericsson W810I Key Pad Replacement: 3 단계, 이미지 2/2
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
  4. Sony Ericsson W810I Key Pad Replacement, Case: 4 단계, 이미지 1/3 Sony Ericsson W810I Key Pad Replacement, Case: 4 단계, 이미지 2/3 Sony Ericsson W810I Key Pad Replacement, Case: 4 단계, 이미지 3/3
    • Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
    • Remove the two 6.35mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson W810I Key Pad Replacement: 5 단계, 이미지 1/3 Sony Ericsson W810I Key Pad Replacement: 5 단계, 이미지 2/3 Sony Ericsson W810I Key Pad Replacement: 5 단계, 이미지 3/3
    • Run a plastic opening tool along the edge of the back casing while prying it apart to remove it.
  6. Sony Ericsson W810I Key Pad Replacement: 6 단계, 이미지 1/3 Sony Ericsson W810I Key Pad Replacement: 6 단계, 이미지 2/3 Sony Ericsson W810I Key Pad Replacement: 6 단계, 이미지 3/3
    • Turn the phone over and open the memory stick compartment.
    • Stick a plastic opening tools into the opening and twist it to gain some leverage. This should begin separating the front casing from the interior plastic support frame.
  7. Sony Ericsson W810I Key Pad Replacement: 7 단계, 이미지 1/3 Sony Ericsson W810I Key Pad Replacement: 7 단계, 이미지 2/3 Sony Ericsson W810I Key Pad Replacement: 7 단계, 이미지 3/3
    • Run the plastic opening tool upwards along that side, removing the housing.
  8. Sony Ericsson W810I Key Pad Replacement, Key Pad: 8 단계, 이미지 1/3 Sony Ericsson W810I Key Pad Replacement, Key Pad: 8 단계, 이미지 2/3 Sony Ericsson W810I Key Pad Replacement, Key Pad: 8 단계, 이미지 3/3
    • Peel the rubber keys away from their backing. Do not slide them off.
    • Set them aside.
  9. Sony Ericsson W810I Key Pad Replacement: 9 단계, 이미지 1/3 Sony Ericsson W810I Key Pad Replacement: 9 단계, 이미지 2/3 Sony Ericsson W810I Key Pad Replacement: 9 단계, 이미지 3/3
    • Insert a plastic opening tool under the left side of the keypad backing and start to lift.
    • Lift slowly, as you can damage the ribbon cable underneath if you pull the keypad backing away too forcefully.
  10. Sony Ericsson W810I Key Pad Replacement: 10 단계, 이미지 1/3 Sony Ericsson W810I Key Pad Replacement: 10 단계, 이미지 2/3 Sony Ericsson W810I Key Pad Replacement: 10 단계, 이미지 3/3
    • Insert the plastic opening tool under the ribbon cable attachment and give a small push upwards to dislodge it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lucy Bowen
회원 가입일: 09/01/11
449 평판
안내서 7개 작성하였습니다
Cuesta, Team 1-7, Zipperian Fall 2011 Cuesta, Team 1-7, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G7
1 회원
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 2,374
