주요 콘텐츠로 건너뛰기
Sony Ericsson W810I Logic Board Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Sony Ericsson W810I Logic Board Replacement, Logic Board: 1 단계, 이미지 1/1
    • Make sure the phone is off and press down firmly against the Cingular icon with your thumb
    • Slide the panel down and remove latch
  2. Sony Ericsson W810I Logic Board Replacement: 2 단계, 이미지 1/2 Sony Ericsson W810I Logic Board Replacement: 2 단계, 이미지 2/2
    • Lift and pull battery out
    • Remove the SIM card if you have one
  3. Sony Ericsson W810I Logic Board Replacement: 3 단계, 이미지 1/1
    • Remove the two outer screws using a T-7 head for a screwdriver
  4. Sony Ericsson W810I Logic Board Replacement: 4 단계, 이미지 1/1
    • Remove the two smaller inner screws with the Mini-Phillips screwdriver head
  5. Sony Ericsson W810I Logic Board Replacement: 5 단계, 이미지 1/2 Sony Ericsson W810I Logic Board Replacement: 5 단계, 이미지 2/2
    • Remove the Back (camera side) Faceplate with the blue hand-wedge
  6. Sony Ericsson W810I Logic Board Replacement: 6 단계, 이미지 1/3 Sony Ericsson W810I Logic Board Replacement: 6 단계, 이미지 2/3 Sony Ericsson W810I Logic Board Replacement: 6 단계, 이미지 3/3
    • Flip the phone over and pry off the front (keypad side) faceplate with multiple blue hand-wedges
    • Separate keypad from logic board by turning it upside down and allowing it to fall off
  7. Sony Ericsson W810I Logic Board Replacement: 7 단계, 이미지 1/2 Sony Ericsson W810I Logic Board Replacement: 7 단계, 이미지 2/2
    • Remove the two remaining screws in the top corners of the phone using a T-6 screwdriver head
    • Remove the logic board with multiple blue hand-wedges, be careful not to snap the logic board in half, along with snapping the wiring from the logic board
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ben Micucci
회원 가입일: 10/14/11
186 평판
안내서 5개 작성하였습니다
James Madison, Team 2-2, Allen Fall 2011 James Madison, Team 2-2, Allen Fall 2011 회원
JMU-ALLEN-F11S2G2
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,623
