주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia Play Battery Replacement
필요한 것
  1. Sony Ericsson Xperia Play Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the phone around so the screen is facing a flat surface.
  2. Sony Ericsson Xperia Play Battery Replacement: 2 단계, 이미지 1/1
    • To remove the cover, use plastic removal tool on the seam of the case.
    • Once enough force is applied, you should hear a “click” sound which indicates that cover is loose.
  3. Sony Ericsson Xperia Play Battery Replacement: 3 단계, 이미지 1/1
    • After the “click” noise, lift the cover with your finger.
    • Do not puncture the battery. This can result in a fire.
  4. Sony Ericsson Xperia Play Battery Replacement: 4 단계, 이미지 1/1
    • Proceed with removing the battery by lifting the battery with a small plastic pry tool.
    • Use a plastic tool for safety. If a plastic tool is not available use your fingers.
  5. Sony Ericsson Xperia Play Battery Replacement: 5 단계, 이미지 1/1
    • Remove the battery from the device.
  6. Sony Ericsson Xperia Play Battery Replacement: 6 단계, 이미지 1/1
    • Once the old battery id removed, slide the new battery, with the positive/negative indicator facing up, in so that the contacts of the battery make contact with the contacts of the phone.
  7. Sony Ericsson Xperia Play Battery Replacement: 7 단계, 이미지 1/1
    • Lightly press the battery into the phone so that it is secure.
  8. Sony Ericsson Xperia Play Battery Replacement: 8 단계, 이미지 1/1
    • To put the cover back on, apply force until a "click" sound is heard.
결론
Pieter Boersma
회원 가입일: 03/25/15
371 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 7-3, Cichon Spring 2015 UMass Dartmouth, Team 7-3, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G3
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
Has ifixit thought about trying to make a replacement battery that would work with this? It would be good to be able to get the battery from here as well, even if it is potentially a niche market for these old phones.
waytodawn0 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 20
전체 시간: 1,590
