주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia Play LCD Display Replacement
필요한 것
동영상 개요
  1. Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: 1 단계, 이미지 1/3 Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: 1 단계, 이미지 2/3 Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: 1 단계, 이미지 3/3
    • Remove the battery cover and the battery.
    • You have the 6x silver screws and 7x black screws and you can remove the rear bezel.
  2. Sony Ericsson Xperia Play LCD Display Replacement: 2 단계, 이미지 1/3 Sony Ericsson Xperia Play LCD Display Replacement: 2 단계, 이미지 2/3 Sony Ericsson Xperia Play LCD Display Replacement: 2 단계, 이미지 3/3
    • By using a plastic tool, disconnect the main flex cable connector. Be careful, near to the connector there are many small elements.
    • Disconnect the gaming keyboard flex cable.
  3. Sony Ericsson Xperia Play LCD Display Replacement: 3 단계, 이미지 1/2 Sony Ericsson Xperia Play LCD Display Replacement: 3 단계, 이미지 2/2
    • Remove the motherboard and the gaming keyboard.
  4. Sony Ericsson Xperia Play LCD Display Replacement: 4 단계, 이미지 1/3 Sony Ericsson Xperia Play LCD Display Replacement: 4 단계, 이미지 2/3 Sony Ericsson Xperia Play LCD Display Replacement: 4 단계, 이미지 3/3
    • Unscrew the 4x black screws.
    • Remove the black sticker on the corner and disconnect the touchscreen flex cable.
    • Disassemble front bezel.
  5. Sony Ericsson Xperia Play LCD Display Replacement: 5 단계, 이미지 1/3 Sony Ericsson Xperia Play LCD Display Replacement: 5 단계, 이미지 2/3 Sony Ericsson Xperia Play LCD Display Replacement: 5 단계, 이미지 3/3
    • Use the thin side of a plastic tool to separate the LCD display from the base bezel.
    • Now you are ready to install the new spare part.
    • I prefer to test the new spare part before the full assembly.
  6. Sony Ericsson Xperia Play LCD Display Replacement: 6 단계, 이미지 1/1
결론
다른 3명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 한 개
Do you have a datasheet for the display? I wanted to reuse it but i cannot find the function of the pins.
jp r - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 32
전체 시간: 4,993
