주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia Play Rear Facing Camera Replacement
필요한 것
  1. Sony Ericsson Xperia Play Rear Facing Camera Replacement, Rear Facing Camera: 1 단계, 이미지 1/1
    • Follow the Prerequisite Guide on how to Remove the Controller Plate/Buttons to prepare the phone for disassembly. Stop when the motherboard has been detached.
    • Orientate the motherboard so that the camera faces away, as shown in the picture.
  2. Sony Ericsson Xperia Play Rear Facing Camera Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • With the camera facing away, pull it from the motherboard until it stands perpendicular to the board. Tweezers can be used to do this.
  3. Sony Ericsson Xperia Play Rear Facing Camera Replacement: 3 단계, 이미지 1/1
    • Use tweezers to pull the camera off of the motherboard. Hold on to the plastic connector and apply the force away from the board.
  4. Sony Ericsson Xperia Play Rear Facing Camera Replacement: 4 단계, 이미지 1/1
    • The camera is now detached.
결론
Pieter Boersma
회원 가입일: 03/25/15
371 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 7-3, Cichon Spring 2015 UMass Dartmouth, Team 7-3, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 820
