주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement
필요한 것
동영상 개요
  1. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 1 단계, 이미지 1/3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 1 단계, 이미지 2/3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 1 단계, 이미지 3/3
    • Remove the battery cover and the battery.
    • Unscrew the 7x black screws and 6x silver screws.
    • Remove the rear bezel.
  2. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 2 단계, 이미지 1/3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 2 단계, 이미지 2/3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 2 단계, 이미지 3/3
    • after removing the 2x black philips screws, use a plastic tool to disconnect the main flex cable connector.
    • Disconnect the gaming keyboard flex cable.
  3. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 3 단계, 이미지 1/2 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 3 단계, 이미지 2/2
    • Remove the motherboard and the gaming keyboard.
  4. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 4 단계, 이미지 1/3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 4 단계, 이미지 2/3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 4 단계, 이미지 3/3
    • Remove the 4x philips screws and the small black sticker on the corner.
    • Disconnect the touchscreen flex cable connector.
    • Disassemble the front bezel.
  5. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 5 단계, 이미지 1/3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 5 단계, 이미지 2/3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 5 단계, 이미지 3/3
    • To separate the touchscreen from the base bezel use hot air and plastic tools.
  6. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 6 단계, 이미지 1/2 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 6 단계, 이미지 2/2
    • Use double side adhesive tape to assemble the touch screen.
  7. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: 7 단계, 이미지 1/1
결론
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,536개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 3,209
