주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia Pro MK16A Camera Replacement
필요한 것
  1. Sony Ericsson Xperia Pro MK16A Camera Replacement, Taking the Back Off: 1 단계, 이미지 1/3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Taking the Back Off: 1 단계, 이미지 2/3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Taking the Back Off: 1 단계, 이미지 3/3
    • Use a plastic opening tool to get the back cover off your phone.
    • The plastic opener will work on any side, but be careful and pry gently.
  2. Sony Ericsson Xperia Pro MK16A Camera Replacement, Removing the Battery: 2 단계, 이미지 1/1
    • Locate the battery in your phone.
    • Find the divot below the battery.
    • Use your thumb to lift the battery out of the phone.
  3. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Screws: 3 단계, 이미지 1/3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Screws: 3 단계, 이미지 2/3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Screws: 3 단계, 이미지 3/3
    • Remove the 4 black screws with the Phillips screwdriver.
    • Remove the 4 silver screws with the Torx screwdriver.
  4. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Back Case: 4 단계, 이미지 1/1
    • Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
  5. Sony Ericsson Xperia Pro MK16A Camera Replacement, Access the Logic Board: 5 단계, 이미지 1/3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Access the Logic Board: 5 단계, 이미지 2/3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Access the Logic Board: 5 단계, 이미지 3/3
    • Remove the last screw that is connecting the logic board using the Phillips screwdriver.
    • Undo the two ribbons.
  6. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove the Logic Board: 6 단계, 이미지 1/3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove the Logic Board: 6 단계, 이미지 2/3 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove the Logic Board: 6 단계, 이미지 3/3
    • Undo that last connector.
  7. Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Camera: 7 단계, 이미지 1/2 Sony Ericsson Xperia Pro MK16A Camera Replacement, Remove Camera: 7 단계, 이미지 2/2
    • Lift the camera off of its connector on the logic board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sean Gallagher
회원 가입일: 10/16/14
66 평판
안내서 1개 작성함
UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G5
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Hi,
my Sony Ericsson Xperia Pro MK16i fell onto the stone floor and now the auto focus of the camera does not work anymore. It takes photos, but they are mostly blurred. Do you know if changing the camera part would fix this problem or is the auto focus function set in some other part than the camera itself? Thank you.
Andrea - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 960
