주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia Pro MK16A Logic Board Replacement
필요한 것
  1. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Taking the Back Off: 1 단계, 이미지 1/3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Taking the Back Off: 1 단계, 이미지 2/3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Taking the Back Off: 1 단계, 이미지 3/3
    • Use a plastic opening tool to get the back cover off your phone.
    • The plastic opener will work on any side, but be careful and pry gently.
  2. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Removing the Battery: 2 단계, 이미지 1/1
    • Locate the battery in your phone.
    • Find the divot below the battery.
    • Use your thumb to lift the battery out of the phone.
  3. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove Screws: 3 단계, 이미지 1/3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove Screws: 3 단계, 이미지 2/3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove Screws: 3 단계, 이미지 3/3
    • Remove the 4 black screws with the Phillips screwdriver.
    • Remove the 4 silver screws with the Torx screwdriver.
  4. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove Back Case: 4 단계, 이미지 1/1
    • Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
  5. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Access the Logic Board: 5 단계, 이미지 1/3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Access the Logic Board: 5 단계, 이미지 2/3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Access the Logic Board: 5 단계, 이미지 3/3
    • Remove the last screw that is connecting the logic board using the Phillips screwdriver.
    • Undo the two ribbons.
  6. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove the Logic Board: 6 단계, 이미지 1/3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove the Logic Board: 6 단계, 이미지 2/3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove the Logic Board: 6 단계, 이미지 3/3
    • Undo that last connector.
결론
Craig
회원 가입일: 10/21/14
55 평판
안내서 1개 작성함
UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,055
