주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia Pro MK16A Power Button Replacement
필요한 것
  1. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: 1 단계, 이미지 1/3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: 1 단계, 이미지 2/3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: 1 단계, 이미지 3/3
    • Use a plastic opening tool to get the back cover off your phone.
    • The plastic opener will work on any side, but be careful and pry gently.
  2. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Removing the Battery: 2 단계, 이미지 1/1
    • Locate the battery in your phone.
    • Find the divot below the battery.
    • Use your thumb to lift the battery out of the phone.
  3. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: 3 단계, 이미지 1/3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: 3 단계, 이미지 2/3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: 3 단계, 이미지 3/3
    • Remove the 4 black screws with the Phillips screwdriver.
    • Remove the 4 silver screws with the Torx screwdriver.
  4. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Back Case: 4 단계, 이미지 1/1
    • Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
  5. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Replacing the Power Button: 5 단계, 이미지 1/2 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Replacing the Power Button: 5 단계, 이미지 2/2
    • When the inner back cover is off, locate and remove the power button.
결론
John Emery
회원 가입일: 10/16/14
65 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 780
