주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia X10 Audio Jack Replacement
필요한 것
  1. Sony Ericsson Xperia X10 Audio Jack Replacement, Audio Jack: 1 단계, 이미지 1개 중 1개
    • The audio jack is located on the top side of the phone, in the center. To access the audio jack disassemble is necessary.
  2. Sony Ericsson Xperia X10 Audio Jack Replacement: 2 단계, 이미지 1개 중 1개
    • Start by having the screen of the phone facing downwards and remove the battery. Remove eight 5mm screws located as shown with a T-6 bit.
  3. Sony Ericsson Xperia X10 Audio Jack Replacement: 3 단계, 이미지 1개 중 1개
    • Using a case opener, start on the bottom right side of the phone and undo clips located at the interior sides. Repeat this step for the left side.
  4. Sony Ericsson Xperia X10 Audio Jack Replacement: 4 단계, 이미지 1개 중 1개
    • Once the clips are undone the back casing should dislocate and reveal the internal components of the phone. Audio jack location is identified on the image.
  5. Sony Ericsson Xperia X10 Audio Jack Replacement: 5 단계, 이미지 2개 중 1개 Sony Ericsson Xperia X10 Audio Jack Replacement: 5 단계, 이미지 2개 중 2개
    • The audio jack can only be accessed if the internal casing is removed. To remove this, apply pressure on the left side of internal casing and using a flat head screw driver unlatch both clips on the right side of casing.
  6. Sony Ericsson Xperia X10 Audio Jack Replacement: 6 단계, 이미지 2개 중 1개 Sony Ericsson Xperia X10 Audio Jack Replacement: 6 단계, 이미지 2개 중 2개
    • Audio Jack is located and easily removed. New component can be inserted.
결론
작성자
3다른 기여자 명과 함께
Bryan
회원 가입일: 11/03/13
410 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 14
전체 시간: 601
