주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia X10 Logic Board Replacement
필요한 것
동영상 개요
  1. Sony Ericsson Xperia X10 Logic Board Replacement, Logic Board: 1 단계, 이미지 1/3 Sony Ericsson Xperia X10 Logic Board Replacement, Logic Board: 1 단계, 이미지 2/3 Sony Ericsson Xperia X10 Logic Board Replacement, Logic Board: 1 단계, 이미지 3/3
    • Switch-off the phone.
    • Remove the battery.
    • Unscrew 8x T6 Torx screws.
  2. Sony Ericsson Xperia X10 Logic Board Replacement: 2 단계, 이미지 1/3 Sony Ericsson Xperia X10 Logic Board Replacement: 2 단계, 이미지 2/3 Sony Ericsson Xperia X10 Logic Board Replacement: 2 단계, 이미지 3/3
    • Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
    • Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
  3. Sony Ericsson Xperia X10 Logic Board Replacement: 3 단계, 이미지 1/3 Sony Ericsson Xperia X10 Logic Board Replacement: 3 단계, 이미지 2/3 Sony Ericsson Xperia X10 Logic Board Replacement: 3 단계, 이미지 3/3
    • Remove the Volume Up/Down and Camera buttons.
    • Unhook the SIM & SD Card reader unit and disconnect the flex cable.
  4. Sony Ericsson Xperia X10 Logic Board Replacement: 4 단계, 이미지 1/3 Sony Ericsson Xperia X10 Logic Board Replacement: 4 단계, 이미지 2/3 Sony Ericsson Xperia X10 Logic Board Replacement: 4 단계, 이미지 3/3
    • Remove the Audio jack connector.
    • Disconnect 4x flex cables:
    • LCD Display
    • Menu buttons
    • Touchscreen
    • Earpiece, Volume & Power On buttons
    • Carefully remove the mother board.
    • Please SUBSCRIBE to my channel ツ
결론
ZFix
회원 가입일: 12/09/13
191,182 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,521개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,946
