주요 콘텐츠로 건너뛰기
Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement
필요한 것
동영상 개요
  1. Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement, Logic Board: 1 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement, Logic Board: 1 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement, Logic Board: 1 단계, 이미지 3개 중 3개
    • Switch-off the phone.
    • Remove the battery.
    • Unscrew 8x T6 Torx screws.
  2. Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 2 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 2 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
    • Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
  3. Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 3 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 3 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the Volume Up/Down and Camera buttons.
    • Unhook the SIM & SD Card reader unit and disconnect the flex cable.
  4. Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 4 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 4 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the Audio jack connector.
    • Disconnect 4x flex cables:
    • LCD Display
    • Menu buttons
    • Touchscreen
    • Earpiece, Volume & Power On buttons
    • Carefully remove the mother board.
    • Please SUBSCRIBE to my channel ツ
  5. Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement, Touchscreen Glass Digitizer: 5 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement, Touchscreen Glass Digitizer: 5 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement, Touchscreen Glass Digitizer: 5 단계, 이미지 3개 중 3개
    • Use a heat gun or a hairdryer and warm the glass.
    • With a cutter carefully make a room between the glass and the frame to insert a Plastic Pick.
    • Slowly separate the Touchscreen from the frame.
  6. Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 6 단계, 이미지 2개 중 1개 Sony Ericsson Xperia X10 Touchscreen Glass Digitizer Replacement: 6 단계, 이미지 2개 중 2개
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,325 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
326 회원들
안내서 1,683개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 1,711
