주요 콘텐츠로 건너뛰기
Sony Ericsson Z500a Keypad Replacement
필요한 것
  1. Sony Ericsson Z500a Keypad Replacement, Keypad: 1 단계, 이미지 1/3 Sony Ericsson Z500a Keypad Replacement, Keypad: 1 단계, 이미지 2/3 Sony Ericsson Z500a Keypad Replacement, Keypad: 1 단계, 이미지 3/3
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 Torx screwdriver, remove the 4 screws.
    • Keep the phone open with the back cover facing you.
  2. Sony Ericsson Z500a Keypad Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
    • There are 2 clamps that lock the keyboard to the case (1 on each side)
  3. Sony Ericsson Z500a Keypad Replacement: 3 단계, 이미지 1/1
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
결론
Jory Benitez
회원 가입일: 04/16/10
1 평판
안내서 1개 작성함
Cal Poly, Team 7-12, Maness Spring 2010 Cal Poly, Team 7-12, Maness Spring 2010 회원
CPSU-MANESS-S10S7G12
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 2,739
