소개
This guide will allow you to remove the inside screen in order to replace it.
부품
부품은 필요하지 않습니다.
  1. Remove the back cover and the battery. Remove the back cover and the battery. Remove the back cover and the battery.
    • Remove the back cover and the battery.
  2. Remove the 4 screws using a T6 precision screwdriver.
    • Remove the 4 screws using a T6 precision screwdriver.
    • Flip open the phone, and keep the back cover facing you.
  3. Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open. There are 2 clamps that lock it to the phone case (1 on each side).
    • Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open.
    • There are 2 clamps that lock it to the phone case (1 on each side).
  4. Flip the phone over and lift straight up on the key pad to remove it.
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table), because there are loose parts that may fall out.
  5. Use the i Pod opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
    • Use the i Pod opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
  6. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  7. Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
    • Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
  8. If the parts are loose you can remove the black sim card reader and green vibrator before continuing, otherwise they may fall out. If the parts are loose you can remove the black sim card reader and green vibrator before continuing, otherwise they may fall out.
    • If the parts are loose you can remove the black sim card reader and green vibrator before continuing, otherwise they may fall out.
  9. Close the phone, flip it over, grab the remaining gray covering of the phone and pull it straight up to remove it. There is another piece below     this which will break if you don't pull straight up.
    • Close the phone, flip it over, grab the remaining gray covering of the phone and pull it straight up to remove it.
    • There is another piece below this which will break if you don't pull straight up.
    • Once the cover is removed take off the black piece underneath.
  10. Remove the face of the phone by sliding down.
    • Remove the face of the phone by sliding down.
  11. Unscrew the 4 screws connecting the screen to the base using a T6 Precision screwdriver.
    • Unscrew the 4 screws connecting the screen to the base using a T6 Precision screwdriver.
  12. Use ipod opening tool to pry up the edge of the remaining silver hinge cover. Once it is loose you can pull it off the rest of the way.
    • Use ipod opening tool to pry up the edge of the remaining silver hinge cover.
    • Once it is loose you can pull it off the rest of the way.
  13. To remove the plastic cover on the screen, run the ipod opening tool along the sides between the cover and the body of the phone (like you did for the keyboard)and gently pry upward until it is loose. Like the keyboard there is one clamp on each side.
    • To remove the plastic cover on the screen, run the ipod opening tool along the sides between the cover and the body of the phone (like you did for the keyboard)and gently pry upward until it is loose.
    • Like the keyboard there is one clamp on each side.
    • Grab the cover at the bottom of the screen (near the hinge) and pull outward while leaving the top (near the speaker) connected.
    • Once the bottom is pulled out far enough the top will be able to disconnect as well.
  14. Remove the tape on the bottom of the screen so that the screen will be able to come out.
    • Remove the tape on the bottom of the screen so that the screen will be able to come out.
    • There is a finger notch on the top of the screen, gently pull out halfway.
    • Caution: the back of the screen is connected to the base of the phone. So do not pull out or the connection will be broken.
  15. Use the iPod opening device to remove the ribbon wire where it connects to the screen.
    • Use the iPod opening device to remove the ribbon wire where it connects to the screen.
결론
Morgan
회원 가입일: 2010년 04월 16일
11 평판
안내서 1개 작성함
Cal Poly, Team 7-12, Maness Spring 2010 Cal Poly, Team 7-12, Maness Spring 2010 회원
CPSU-MANESS-S10S7G12
4 회원들
안내서 10개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,815
