주요 콘텐츠로 건너뛰기
Sony Ericsson s710a Keypad Replacement
필요한 것
  1. Sony Ericsson s710a Keypad Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a Keypad Replacement: 2 단계, 이미지 1/1
    • Pull the battery out using your finger.
  3. Sony Ericsson s710a Keypad Replacement: 3 단계, 이미지 1/1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a Keypad Replacement, Keypad: 4 단계, 이미지 1/1
    • Remove the four screws using a Phillips #00 screwdriver.
  5. Sony Ericsson s710a Keypad Replacement: 5 단계, 이미지 1/1
    • Remove the plastic cover with the iFixit opening tool.
    • It is easiest to begin at the SD card slot and alternate prying the cover on opposite sides.
    • The cover will not come off completely, because there are additional screws that need to be removed, but will pry loose up to the camera.
  6. Sony Ericsson s710a Keypad Replacement: 6 단계, 이미지 1/1
    • Using the iFixit opening tool, pry off the plastic piece at the bottom of the keypad.
    • This piece is fixed with an adhesive, so you must break the bond to reach the screws underneath. It may be necessary to use additional adhesive during reassembly.
  7. Sony Ericsson s710a Keypad Replacement: 7 단계, 이미지 1/1
    • Remove two 6 mm screws from beneath the previously removed plastic cover using a Phillips #00 screwdriver.
    • Completely remove the back plastic cover.
  8. Sony Ericsson s710a Keypad Replacement: 8 단계, 이미지 1/2 Sony Ericsson s710a Keypad Replacement: 8 단계, 이미지 2/2
    • Pry the board from the plastic case using the iFixit opening tool.
    • This part is tricky. The black plastic pieces at the base of the phone hold the board in.
  9. Sony Ericsson s710a Keypad Replacement: 9 단계, 이미지 1/1
    • After removing the board, you will see the plastic keyboard beneath. This can be removed by hand and is very flexible.
    • You have successfully removed the keypad. You can clean, decorate, or replace the keyboard without worrying about damaging the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexander
회원 가입일: 10/29/11
75 평판
안내서 4개 작성하였습니다
University of Maryland, Team 1-1, Calloway Fall 2011 University of Maryland, Team 1-1, Calloway Fall 2011 회원
UMD-CALLOWAY-F11S1G1
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,339
