주요 콘텐츠로 건너뛰기
Sony Ericsson s710a LCD Screen Replacement
필요한 것
  1. Sony Ericsson s710a LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the battery out using your finger.
  3. Sony Ericsson s710a LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1개 중 1개
    • Remove the four 6 mm screws from beneath the battery using a Phillips #00 screwdriver.
  5. Sony Ericsson s710a LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the microphone cover using the iFixit opening tool.
  6. Sony Ericsson s710a LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 6 mm screws from the front of the phone beneath the microphone cover using a Phillips #00 screwdriver.
  7. Sony Ericsson s710a LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the black plastic piece on the side.
    • This will allow for easier access while prying the motherboard.
  8. Sony Ericsson s710a LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Use the iFixit opening tool to loosen the motherboard from the phone.
  9. Sony Ericsson s710a LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the motherboard out with your fingers.
    • Pull slowly. This will require some force.
  10. Sony Ericsson s710a LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the two cable connectors using the iFixit opening tool.
    • Mark the orientation and port of each cable before detaching them. The connectors are symmetrical, so this is essential for reassembly.
  11. Sony Ericsson s710a LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • On the rotational assembly remove the following screws:
    • Four 3 mm screws
    • Two 2.3 mm screws
    • Lift the rotational assembly off of the phone to allow access to the other half of the device.
  12. Sony Ericsson s710a LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Detach the cable connectors on the other end of the cables using a plastic opening tool.
    • Record the orientation and location of each connector for reassembly.
  13. Sony Ericsson s710a LCD Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the plastic cover on the back of the phone using an iFixit opening tool.
    • Remove the four 6 mm screws using a Phillips #00 screwdriver.
  14. Sony Ericsson s710a LCD Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Pry the screen assembly from the main case using the iFixit opening tool.
  15. Sony Ericsson s710a LCD Screen Replacement: 15 단계, 이미지 1개 중 1개
    • With the face plate and LCD screen exposed, replace the existing LCD screen with a new LCD screen.
    • Be sure to test and make sure the detachable connections are arranged correctly.
결론
작성자
9다른 기여자 명과 함께
Jamel Lugg
회원 가입일: 10/29/11
1 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 1,593
