주요 콘텐츠로 건너뛰기
Sony Ericsson s710a Main Interface Buttons Replacement
필요한 것
  1. Sony Ericsson s710a Main Interface Buttons Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a Main Interface Buttons Replacement: 2 단계, 이미지 1/1
    • Pull the battery out using your finger.
  3. Sony Ericsson s710a Main Interface Buttons Replacement: 3 단계, 이미지 1/1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a Main Interface Buttons Replacement, LCD Screen: 4 단계, 이미지 1/1
    • Remove the four 6 mm screws from beneath the battery using a Phillips #00 screwdriver.
  5. Sony Ericsson s710a Main Interface Buttons Replacement: 5 단계, 이미지 1/1
    • Remove the microphone cover using the iFixit opening tool.
  6. Sony Ericsson s710a Main Interface Buttons Replacement: 6 단계, 이미지 1/1
    • Remove the two 6 mm screws from the front of the phone beneath the microphone cover using a Phillips #00 screwdriver.
  7. Sony Ericsson s710a Main Interface Buttons Replacement: 7 단계, 이미지 1/1
    • Remove the black plastic piece on the side.
    • This will allow for easier access while prying the motherboard.
  8. Sony Ericsson s710a Main Interface Buttons Replacement: 8 단계, 이미지 1/1
    • Use the iFixit opening tool to loosen the motherboard from the phone.
  9. Sony Ericsson s710a Main Interface Buttons Replacement: 9 단계, 이미지 1/1
    • Lift the motherboard out with your fingers.
    • Pull slowly. This will require some force.
  10. Sony Ericsson s710a Main Interface Buttons Replacement: 10 단계, 이미지 1/1
    • Remove the two cable connectors using the iFixit opening tool.
    • Mark the orientation and port of each cable before detaching them. The connectors are symmetrical, so this is essential for reassembly.
  11. Sony Ericsson s710a Main Interface Buttons Replacement: 11 단계, 이미지 1/1
    • On the rotational assembly remove the following screws:
    • Four 3 mm screws
    • Two 2.3 mm screws
    • Lift the rotational assembly off of the phone to allow access to the other half of the device.
  12. Sony Ericsson s710a Main Interface Buttons Replacement: 12 단계, 이미지 1/1
    • Detach the cable connectors on the other end of the cables using a plastic opening tool.
    • Record the orientation and location of each connector for reassembly.
  13. Sony Ericsson s710a Main Interface Buttons Replacement: 13 단계, 이미지 1/1
    • Remove the plastic cover on the back of the phone using an iFixit opening tool.
    • Remove the four 6 mm screws using a Phillips #00 screwdriver.
  14. Sony Ericsson s710a Main Interface Buttons Replacement: 14 단계, 이미지 1/1
    • Pry the screen assembly from the main case using the iFixit opening tool.
  15. Sony Ericsson s710a Main Interface Buttons Replacement: 15 단계, 이미지 1/1
    • With the face plate and LCD screen exposed, replace the existing LCD screen with a new LCD screen.
    • Be sure to test and make sure the detachable connections are arranged correctly.
  16. Sony Ericsson s710a Main Interface Buttons Replacement, Main Interface Buttons: 16 단계, 이미지 1/1
    • Remove the button and pad assembly as shown.
    • If desired, these items can now be cleaned or replaced.
결론
Alexander
회원 가입일: 10/29/11
75 평판
안내서 4개 작성하였습니다
University of Maryland, Team 1-1, Calloway Fall 2011 University of Maryland, Team 1-1, Calloway Fall 2011 회원
UMD-CALLOWAY-F11S1G1
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 954
