소개
The headphone jack will need to be replaced it it no longer outputs audio.
필요한 것
Open the flaps and remove the back cover using the plastic opening device.
Remove the battery shield with the plastic opening device.
Unscrew the 5mm screws with the T5 head.
Unscrew the 6mm screw with the T6 head.
Remove the black cover with the plastic opening tool.
Remove the headphone jack from its slot.
다른 3명이 해당 안내서를 완성하였습니다.
