주요 콘텐츠로 건너뛰기
Sony Ericsson xPeria Active Headphone Jack Replacement
필요한 것
  1. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the back cover.: 1 단계, 이미지 1/3 Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the back cover.: 1 단계, 이미지 2/3 Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the back cover.: 1 단계, 이미지 3/3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove inside plastic battery cover.: 2 단계, 이미지 1/2 Sony Ericsson xPeria Active Headphone Jack Replacement, Remove inside plastic battery cover.: 2 단계, 이미지 2/2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the battery: 3 단계, 이미지 1/2 Sony Ericsson xPeria Active Headphone Jack Replacement, Remove the battery: 3 단계, 이미지 2/2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Headphone Jack Replacement, Unfastening The Motherboard Cover: 4 단계, 이미지 1/1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Headphone Jack Replacement, Removing The Motherboard Cover: 5 단계, 이미지 1/2 Sony Ericsson xPeria Active Headphone Jack Replacement, Removing The Motherboard Cover: 5 단계, 이미지 2/2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Daniel
회원 가입일: 10/13/14
437 평판
안내서 2개 작성하였습니다
USF Tampa, Team 14-5, Leahy Fall 2014 USF Tampa, Team 14-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S14G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 741
