주요 콘텐츠로 건너뛰기
Sony Ericsson xPeria Active Screen Replacement
필요한 것
  1. Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: 1 단계, 이미지 1/3 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: 1 단계, 이미지 2/3 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: 1 단계, 이미지 3/3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: 2 단계, 이미지 1/2 Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: 2 단계, 이미지 2/2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Screen Replacement, Remove the battery: 3 단계, 이미지 1/2 Sony Ericsson xPeria Active Screen Replacement, Remove the battery: 3 단계, 이미지 2/2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Screen Replacement, Unfastening The Motherboard Cover: 4 단계, 이미지 1/1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: 5 단계, 이미지 1/2 Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: 5 단계, 이미지 2/2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Screen Replacement, Screen: 6 단계, 이미지 1/2 Sony Ericsson xPeria Active Screen Replacement, Screen: 6 단계, 이미지 2/2
    • Unplug the power cable by carefully prying it away from the motherboard.
  7. Sony Ericsson xPeria Active Screen Replacement: 7 단계, 이미지 1/2 Sony Ericsson xPeria Active Screen Replacement: 7 단계, 이미지 2/2
    • Remove the power strip on the back side of the motherboard.
  8. Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: 8 단계, 이미지 1/2 Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: 8 단계, 이미지 2/2
    • Remove the shield.
  9. Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: 9 단계, 이미지 1/2 Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: 9 단계, 이미지 2/2
    • Push the screen through the front of the case, gently.
    • It may be a little tough, just work your way around the edges of the screen until it separates from the main case.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Alex Tobin
회원 가입일: 10/06/14
406 평판
안내서 3개 작성하였습니다
USF Tampa, Team 14-5, Leahy Fall 2014 USF Tampa, Team 14-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S14G5
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
hi can you add explain
abdnour master2 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 23
전체 시간: 2,356
