주요 콘텐츠로 건너뛰기
Sony Ericsson z300 Back Speaker Replacement
필요한 것
  1. Sony Ericsson z300 Back Speaker Replacement, Back Phone Cover: 1 단계, 이미지 1/1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Back Speaker Replacement, Battery: 2 단계, 이미지 1/1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Back Speaker Replacement, Sim Card: 3 단계, 이미지 1/1
    • Slide the sim card out with your thumb.
  4. Sony Ericsson z300 Back Speaker Replacement, Back Dark Grey Case: 4 단계, 이미지 1/1
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Sony Ericsson z300 Back Speaker Replacement: 5 단계, 이미지 1/1
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  6. Sony Ericsson z300 Back Speaker Replacement: 6 단계, 이미지 1/1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Back Speaker Replacement, Back Speaker: 7 단계, 이미지 1/1
    • Use a plastic opening tool to lift the speaker out of the back case.
결론
Alex Serventi
회원 가입일: 10/07/10
65 평판
안내서 13개 작성하였습니다
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010 회원
CPSU-MANESS-F10S5G15
4 회원들
안내서 26개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 953
