이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide shows how to remove the Screens.
필요한 것
To remove the back cover, use your thumb to press down on the center of case and slide it off.
To remove the front cover, lift up the case with a fingernail in the small slot as shown.
To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
거의 끝나갑니다!
결론
