주요 콘텐츠로 건너뛰기
Sony Ericsson z300 Vibrator Replacement
필요한 것
  1. Sony Ericsson z300 Vibrator Replacement, Back Phone Cover: 1 단계, 이미지 1/1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Vibrator Replacement, Battery: 2 단계, 이미지 1/1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Vibrator Replacement, Front Phone Cover: 3 단계, 이미지 1/1
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. Sony Ericsson z300 Vibrator Replacement, Front Dark Grey Case: 4 단계, 이미지 1/1
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Sony Ericsson z300 Vibrator Replacement: 5 단계, 이미지 1/1
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  6. Sony Ericsson z300 Vibrator Replacement: 6 단계, 이미지 1/1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Vibrator Replacement, Screens: 7 단계, 이미지 1/1
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  8. Sony Ericsson z300 Vibrator Replacement: 8 단계, 이미지 1/1
    • Lift the ribbon cable connector lock using a plastic opening tool.
  9. Sony Ericsson z300 Vibrator Replacement: 9 단계, 이미지 1/2 Sony Ericsson z300 Vibrator Replacement: 9 단계, 이미지 2/2
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  10. Sony Ericsson z300 Vibrator Replacement: 10 단계, 이미지 1/2 Sony Ericsson z300 Vibrator Replacement: 10 단계, 이미지 2/2
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  11. Sony Ericsson z300 Vibrator Replacement: 11 단계, 이미지 1/1
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
  12. Sony Ericsson z300 Vibrator Replacement, Vibrator: 12 단계, 이미지 1/1
    • Use a plastic opening tool to lift the vibrator out of its slot.
결론
Alex Serventi
회원 가입일: 10/07/10
65 평판
안내서 13개 작성하였습니다
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010 회원
CPSU-MANESS-F10S5G15
4 회원들
안내서 26개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 2,169
