주요 콘텐츠로 건너뛰기
Sony H.ear On 2 Ear Cup Replacement
필요한 것
  1. Sony H.ear On 2 Ear Cup Replacement, Ear Cup: 1 단계, 이미지 1/2 Sony H.ear On 2 Ear Cup Replacement, Ear Cup: 1 단계, 이미지 2/2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
  2. Sony H.ear On 2 Ear Cup Replacement: 2 단계, 이미지 1/2 Sony H.ear On 2 Ear Cup Replacement: 2 단계, 이미지 2/2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alec Saffer
회원 가입일: 04/15/19
522 평판
안내서 2개 작성하였습니다
Cal Poly, Team S9-G11, Maness Spring 2019 Cal Poly, Team S9-G11, Maness Spring 2019 회원
CPSU-MANESS-S19S9G11
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 38
전체 시간: 3,322
