주요 콘텐츠로 건너뛰기
Sony H.ear on 3 Left Ear Pad Replacement
필요한 것
  1. Sony H.ear on 3 Left Ear Pad Replacement, Extend the Left Speaker: 1 단계, 이미지 2개 중 1개 Sony H.ear on 3 Left Ear Pad Replacement, Extend the Left Speaker: 1 단계, 이미지 2개 중 2개
    • Extend the Left cup and fold the Right cup away via the headband.
    • This will help protect the other ear pad while you work on this one.
  2. Sony H.ear on 3 Left Ear Pad Replacement, Unclip the Left Ear Pad: 2 단계, 이미지 3개 중 1개 Sony H.ear on 3 Left Ear Pad Replacement, Unclip the Left Ear Pad: 2 단계, 이미지 3개 중 2개 Sony H.ear on 3 Left Ear Pad Replacement, Unclip the Left Ear Pad: 2 단계, 이미지 3개 중 3개
    • The pad is attached by 6 clips in a hexagonal pattern, shown by the arrows.
    • Starting from the top, insert an opening pick in between where the cup leather meets the plastic casing, push it in firmly, then twist it until you disengage the top clip.
    • Try not to damage or peel off the leather while doing this. It helps if you pry towards the speaker housing, not the leather cup.
    • Work round the back side, poking the pick in and twisting to disengage further clips until you can gently pull the cup away.
    • When re-assembling, make sure that the stitching line on the ear pad is facing the bottom.
결론
작성자
1다른 기여자 명과 함께
Caius Nocturne
회원 가입일: 07/12/21
2,076 평판
안내서 13개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 737
