주요 콘텐츠로 건너뛰기
Sony HDR-AS30V Outer Casing Replacement
필요한 것
  1. Sony HDR-AS30V Outer Casing Replacement, Outer Casing: 1 단계, 이미지 1/1
    • Power off the device. Remove the component jack cover.
    • Open component door.
    • Using the Phillips 00 screwdriver, remove the two screws holding the jack cover in place.
  2. Sony HDR-AS30V Outer Casing Replacement: 2 단계, 이미지 1/1
    • Open the battery door.
    • Slide the battery cap along the length of the camera, then flip the cap outward. Use caution; there may be internal damage affecting the functionality of the sliding mechanism.
  3. Sony HDR-AS30V Outer Casing Replacement: 3 단계, 이미지 1/1
    • Prepare to remove outer casing.
    • Using the 2.5 mm precision slotted screwdriver, insert the tip of the screwdriver under the holder to wedge. Use caution when preparing to wedge apart fragile components.
  4. Sony HDR-AS30V Outer Casing Replacement: 4 단계, 이미지 1/1
    • Separate Casing from Device.
    • With the screwdriver wedged, apply slight force while pulling the casing away from the device. Use caution to avoid causing damage to fragile parts.
  5. Sony HDR-AS30V Outer Casing Replacement: 5 단계, 이미지 1/1
    • With the outer casing pulled away from the device, take note of the orientation of the inner component to avoid an electrical short.
    • Once the orientation of the inner component is noted, slide the inner component out of the casing. You may now replace the broken casing with a new one.
결론
Patrick Finney
회원 가입일: 01/27/15
101 평판
안내서 1개 작성함
Penn State, Team 2-12, Kaschak Winter 2015 Penn State, Team 2-12, Kaschak Winter 2015 회원
PSU-KASCHAK-W15S2G12
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 830
