소개
This guide will take you though the process of replacing a faulty or non-functioning microphone in your Sony Handycam.
부품
No parts specified.
  1. Using a Phillips #00 screwdriver, remove (1) screw from bottom, (1) screw from side, (1) from top of camera
    • Using a Phillips #00 screwdriver, remove (1) screw from bottom, (1) screw from side, (1) from top of camera
  2. Remove tops screws from microphone
    • Remove tops screws from microphone
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove electrical connector from circuit board
    • Remove electrical connector from circuit board
  5. After screws are removed, microphone will detach from camera. Your microphone is now disassembled from camcorder.
    • After screws are removed, microphone will detach from camera. Your microphone is now disassembled from camcorder.
결론
Emma
회원 가입일: 2011년 10월 06일
47 평판
안내서 4개 작성하였습니다
UW Stout, Team 1-4, Zhou Fall 2011 UW Stout, Team 1-4, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G4
5 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 840
