주요 콘텐츠로 건너뛰기
Sony Handycam CCD-TR5 Video/Audio Input/Output Replacement
필요한 것
  1. Sony Handycam CCD-TR5 Video/Audio Input/Output Replacement, Video/Audio Input/Output: 1 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the eight screws located on the bottom of the camera.
  2. Sony Handycam CCD-TR5 Video/Audio Input/Output Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the five cassette side cover screws.
  3. Sony Handycam CCD-TR5 Video/Audio Input/Output Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two top microphone screws.
    • Remove the microphone and cassette side cover.
  4. Sony Handycam CCD-TR5 Video/Audio Input/Output Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two screws from the Input/Output.
    Is this a problem why I'm not hearing sound from my tapes when I go to play them back
    Kelly - 답글
  5. Sony Handycam CCD-TR5 Video/Audio Input/Output Replacement: 5 단계, 이미지 1/2 Sony Handycam CCD-TR5 Video/Audio Input/Output Replacement: 5 단계, 이미지 2/2
    • Gently remove the Input/Output plug from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aaron Hovde
회원 가입일: 10/04/11
101 평판
안내서 1개 작성함
UW Stout, Team 1-4, Zhou Fall 2011 UW Stout, Team 1-4, Zhou Fall 2011 회원
UWSTOUT-ZHOU-F11S1G4
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
Hey where can I get this replacement part?? Miami, USA thx
gerardzz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 16
전체 시간: 3,903
