소개
This guide will teach you how to replace the battery port on your Sony Handycam CX260V.
필요한 것
Use a Phillips #00 screwdriver to remove the one 3mm and two 5mm screws located in the battery assembly area.
Unplug the battery port connected to the frame/motherboard. Remove the battery port.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
