소개
This guide will provide accurate steps in replacing the Camera Lens for the CX260V.
필요한 것
Use a Phillips #00 screwdriver to remove the one 3mm and two 5mm screws located in the battery assembly area.
Using the PH #00 size screw driver, unscrew one 5 millimeter screw located on the top left near the lens of the camera.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
