주요 콘텐츠로 건너뛰기
Sony Handycam DCR-DVD103 LCD Screen Replacement
필요한 것
  1. Sony Handycam DCR-DVD103 LCD Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 LCD Screen Replacement, Outer Cover: 3 단계, 이미지 1/1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 LCD Screen Replacement: 4 단계, 이미지 1/2 Sony Handycam DCR-DVD103 LCD Screen Replacement: 4 단계, 이미지 2/2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 LCD Screen Replacement: 6 단계, 이미지 1/2 Sony Handycam DCR-DVD103 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 LCD Screen Replacement: 7 단계, 이미지 1/2 Sony Handycam DCR-DVD103 LCD Screen Replacement: 7 단계, 이미지 2/2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 LCD Screen Replacement: 8 단계, 이미지 1/1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 LCD Screen Replacement: 9 단계, 이미지 1/1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
  10. Sony Handycam DCR-DVD103 LCD Screen Replacement, LCD Screen: 10 단계, 이미지 1/1
    • Remove the copper strip from the housing that connects the outer casing to the entire of the camera.
    • Use caution when removing the wire, too much force may cause it to tear.
  11. Sony Handycam DCR-DVD103 LCD Screen Replacement: 11 단계, 이미지 1/3 Sony Handycam DCR-DVD103 LCD Screen Replacement: 11 단계, 이미지 2/3 Sony Handycam DCR-DVD103 LCD Screen Replacement: 11 단계, 이미지 3/3
    • Remove (4) 2.9mm screws from the L-shaped circuit board. They are marked with red circles in the slide.
    • Remove the (3) wire strips connected to the camera so you can pull off the L-shaped circuit board.
    • Remove the single wire strip that is connected to the bottom of the circuit board.
  12. Sony Handycam DCR-DVD103 LCD Screen Replacement: 12 단계, 이미지 1/1
    • Remove the (2) 4.5mm screws.
    • Remove the small black holder from above the base of the LCD screen.
  13. Sony Handycam DCR-DVD103 LCD Screen Replacement: 13 단계, 이미지 1/1
    • Remove (1) 2.9mm screw from the base of the LCD screen.
  14. Sony Handycam DCR-DVD103 LCD Screen Replacement: 14 단계, 이미지 1/1
    • Remove the silver and black, front and back casings from the base of the screen.
    • Remove one copper strip from the inside of the bottom case.
  15. Sony Handycam DCR-DVD103 LCD Screen Replacement: 15 단계, 이미지 1/1
    • Remove (2) 5.4mm screws that are securing the screen to the cover, from the base of the LCD.
  16. Sony Handycam DCR-DVD103 LCD Screen Replacement: 16 단계, 이미지 1/3 Sony Handycam DCR-DVD103 LCD Screen Replacement: 16 단계, 이미지 2/3 Sony Handycam DCR-DVD103 LCD Screen Replacement: 16 단계, 이미지 3/3
    • Twist out the screen from the cover.
    • Be careful not to break the casing when trying to get the screen out, as it does require some maneuvering.
  17. Sony Handycam DCR-DVD103 LCD Screen Replacement: 17 단계, 이미지 1/1
    • Remove (2) 3.8mm screws from the end of the LCD.
  18. Sony Handycam DCR-DVD103 LCD Screen Replacement: 18 단계, 이미지 1/1
    • Remove (2) 3.8mm screws from the bottom of the LCD.
  19. Sony Handycam DCR-DVD103 LCD Screen Replacement: 19 단계, 이미지 1/2 Sony Handycam DCR-DVD103 LCD Screen Replacement: 19 단계, 이미지 2/2
    • Pull off the silver cover on the screen, which will reveal the circuit board from behind the screen itself.
    • Pull off the black tape stuck to both sides of the circuit board.
  20. Sony Handycam DCR-DVD103 LCD Screen Replacement: 20 단계, 이미지 1/1
    • Remove (3) 4.5mm screws from back-side of the LCD.
  21. Sony Handycam DCR-DVD103 LCD Screen Replacement: 21 단계, 이미지 1/3 Sony Handycam DCR-DVD103 LCD Screen Replacement: 21 단계, 이미지 2/3 Sony Handycam DCR-DVD103 LCD Screen Replacement: 21 단계, 이미지 3/3
    • Remove the (3) copper strips to remove both the screen and the back light.
    • Replace what is broken.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
kaitlin
회원 가입일: 01/11/11
342 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-44, Regan Winter 2011 Cal Poly, Team 7-44, Regan Winter 2011 회원
CPSU-REGAN-W11S7G44
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 8,046
