소개
Use this repair guide to remove and replace the Sony Handycam DCR DVD103 lens.
If the Sony Handycam DCR DVD103 has a cracked or broken lens, this repair guide will help the camera perform as designed. This repair does not require special skills.
The camera featured in this repair guide does not contain a battery.
필요한 것
On the back of the camera beneath the viewfinder, locate the battery pack.
Press the small button.
Slide the switch forward.
Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
다른 2명이 해당 안내서를 완성하였습니다.
