주요 콘텐츠로 건너뛰기
Sony Handycam DCR-DVD103 Outer Cover Replacement
필요한 것
  1. Sony Handycam DCR-DVD103 Outer Cover Replacement, Battery: 1 단계, 이미지 1/1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Outer Cover Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Outer Cover Replacement, Outer Cover: 3 단계, 이미지 1/1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 Outer Cover Replacement: 4 단계, 이미지 1/2 Sony Handycam DCR-DVD103 Outer Cover Replacement: 4 단계, 이미지 2/2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 Outer Cover Replacement: 5 단계, 이미지 1/1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 Outer Cover Replacement: 6 단계, 이미지 1/2 Sony Handycam DCR-DVD103 Outer Cover Replacement: 6 단계, 이미지 2/2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 Outer Cover Replacement: 7 단계, 이미지 1/2 Sony Handycam DCR-DVD103 Outer Cover Replacement: 7 단계, 이미지 2/2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 Outer Cover Replacement: 8 단계, 이미지 1/1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 Outer Cover Replacement: 9 단계, 이미지 1/1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
kaitlin
회원 가입일: 01/11/11
342 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-44, Regan Winter 2011 Cal Poly, Team 7-44, Regan Winter 2011 회원
CPSU-REGAN-W11S7G44
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 20
전체 시간: 2,458
