소개
The LCD Screen is a crucial component to the playback of the camera. The camera will most likely take pictures if the LCD Screen is broken, but will be unable to show the pictures or setting options through the screen. If you wish to change the resolution settings on the camera, a broken or damaged LCD Screen must be fixed.
필요한 것
Remove the battery.
Use Philips #000 screwdriver to remove the 3mm screw under the battery
다른 2명이 해당 안내서를 완성하였습니다.
