주요 콘텐츠로 건너뛰기
Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement
필요한 것
  1. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): 1 단계, 이미지 1/1
    • Undo Hand Strap
    • Remove battery.
    • Get the iFixit screwdriver and remove the extension.
    • Use a JO Philips head bit.
  2. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 2 단계, 이미지 1/2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 2 단계, 이미지 2/2
    • Place device on left side with lens facing right.
    • Using the screwdriver, unscrew the left middle 3mm Philips screw.
    • Open the "DC IN" tabe. (Second 3mm Philips screw is revealed)
    • Unscrew this screw.
  3. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 3 단계, 이미지 1/1
    • Turn device over onto it's top with the lens facing right.
    • Unscrew the top left and top right 3mm Philips screws.
    • The right side casing is now free.
  4. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 4 단계, 이미지 1/2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 4 단계, 이미지 2/2
    • Remove the right side casing by pulling up and away.
    • The HDD is now revealed.
  5. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 5 단계, 이미지 1/3 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 5 단계, 이미지 2/3 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 5 단계, 이미지 3/3
    • Using your fingers, lift the HDD from it's right end, pivoting on it's left end.
    • The HDD ribbon wire is now exposed.
  6. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 6 단계, 이미지 1/2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 6 단계, 이미지 2/2
    • Using your fingers, gently pull the ribbon wire out of it's socket.
    • The HDD is now free from the device.
  7. Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 7 단계, 이미지 1/2 Sony Handycam DCR-SR68 Hard Disk Drive (HDD) Replacement: 7 단계, 이미지 2/2
    • Using your fingers, pull the black rubber bumpers off of the HDD.
    • Set the old HDD aside.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Michael Smith
회원 가입일: 01/06/16
197 평판
안내서 1개 작성함
댓글 7개
Hi. Would you know if the hard drive of the sr67 would work in a sr 68? My sony handycam dcr sr67 Got water damage and I need to download videos. Can't find an old 67. 0nly 68. No one can fix the old one. Thanks renee
Renee - 답글
What does the letter H after hte HDD1818 stands for?
guimoramirez - 답글
My dcr-sr68 hdd not formting please find salution
Naman Jain - 답글
My SONY HANDYCAM DCR - SR68 HDD FORMATING shows Error E:31.00
What does it mean ?
Daanish - 답글
My sony handycam DCR-SR68 HDD not formating plz find
bharat kumar solanki - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 119
전체 시간: 9,735
