소개
Can't save all those breathtaking moments without an operating SD card slot! This guide will guide you through removing the outer casing and replacing the SD card slot.
필요한 것
Use the blunt tweezers to unplug the red and black wire by pulling out and away./Provide a better close up of the picture.
Gently unplug the small ribbon wire./Provide a better close up of the picture.
Unscrew the top three 3mm Philips screws with the Phillips precision screwdriver. /Unscrew the top three 3mm Phillips screws with the Phillips precision screwdriver./Provide a better close up for this picture.
On the top of the device, unscrew the right 3mm Philips screw with the Phillips precision screwdriver/Get a close up of the screw in this picture.
On the left side of the device, unscrew the bottom left 3mm Philips screw wit the screwdriver./Same thing with this picture. A close of the screw would help readers.
Set the device facing forward, with its bottom down.
While securing the device with your left hand, use gentle rightward pressure with a plastic opening tool to pop off the shutter assembly. To do this, position the plastic opening tool in the slot labeled in photo one. A close up of the shutter assembly in the picture might help also.
On the left side of the device (with the front lens facing left), unscrew the left middle 3mm Philips screw with the screwdriver./A close up of the screw in the picture would be better.
Carefully pivot the dismantled piece of the device until the ribbon wires are fully exposed./Carefully pivot the dismantled piece of the device until the ribbon wires are fully exposed.
To reassemble your device, follow these instructions in reverse order in addition to the Lens Replacement Guide.
댓글 한 개
Hello everyone,
First, sorry for my bad english.
I would like to replace the memory slot in my DCR-SX34 camera because it doesn't recognize any card, even formatted ones, but I can't find it, where to buy it?
Please
thank you
