주요 콘텐츠로 건너뛰기
Sony Handycam HDR­-CX220 Camera's Body Replacement
필요한 것
  1. Sony Handycam HDR­-CX220 Camera's Body  Replacement, Battery: 1 단계, 이미지 1/1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Camera's Body  Replacement: 2 단계, 이미지 1/1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Camera's Body  Replacement, Camera's Body: 3 단계, 이미지 1/3 Sony Handycam HDR­-CX220 Camera's Body  Replacement, Camera's Body: 3 단계, 이미지 2/3 Sony Handycam HDR­-CX220 Camera's Body  Replacement, Camera's Body: 3 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Camera's Body  Replacement: 4 단계, 이미지 1/3 Sony Handycam HDR­-CX220 Camera's Body  Replacement: 4 단계, 이미지 2/3 Sony Handycam HDR­-CX220 Camera's Body  Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Camera's Body  Replacement: 5 단계, 이미지 1/1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
결론
Keven
회원 가입일: 03/11/16
811 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 8-5, Botvin Spring 2016 UMass Dartmouth, Team 8-5, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 711
