주요 콘텐츠로 건너뛰기
Sony Handycam HDR­-CX220 Display Screen Replacement
필요한 것
  1. Sony Handycam HDR­-CX220 Display Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Display Screen Replacement: 2 단계, 이미지 1/1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: 3 단계, 이미지 1/3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: 3 단계, 이미지 2/3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: 3 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Display Screen Replacement: 4 단계, 이미지 1/3 Sony Handycam HDR­-CX220 Display Screen Replacement: 4 단계, 이미지 2/3 Sony Handycam HDR­-CX220 Display Screen Replacement: 4 단계, 이미지 3/3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Display Screen Replacement: 5 단계, 이미지 1/1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: 6 단계, 이미지 1/2 Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: 6 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
    • In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
  7. Sony Handycam HDR­-CX220 Display Screen Replacement: 7 단계, 이미지 1/1
    • Use the plastic opening tool to remove the plastic case protecting the screen
    • Pull it gently not to damage anything under the case
  8. Sony Handycam HDR­-CX220 Display Screen Replacement: 8 단계, 이미지 1/2 Sony Handycam HDR­-CX220 Display Screen Replacement: 8 단계, 이미지 2/2
    • Use the Phillips #0 screwdriver to remove the 2 screws shown
    • Use your hands to carefully unhook the screen from the highlighted hook
  9. Sony Handycam HDR­-CX220 Display Screen Replacement: 9 단계, 이미지 1/3 Sony Handycam HDR­-CX220 Display Screen Replacement: 9 단계, 이미지 2/3 Sony Handycam HDR­-CX220 Display Screen Replacement: 9 단계, 이미지 3/3
    • Use your hands to carefully remove the tape
    • After removing the tape, pull on the wire disconnecting it from the screen.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Keven
회원 가입일: 03/11/16
811 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 8-5, Botvin Spring 2016 UMass Dartmouth, Team 8-5, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G5
3 회원들
안내서 12개 작성하였습니다
댓글 3개
How do you mount hdr cx220 lcd cable flat? can you help me?
Rafael Oliveira - 답글
gjhgvnvyh n hygfv
ANM WORLD - 답글
We have a camera 220. Whose dipstick display strip has deteriorated again. Where can I find this strip? Video is good information so that's why
ANM WORLD - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 25
전체 시간: 2,489
