주요 콘텐츠로 건너뛰기
Sony Handycam HDR-CX380 Camera Shell Replacement
필요한 것
  1. Sony Handycam HDR-CX380 Camera Shell Replacement, Battery: 1 단계, 이미지 1/1
    • Rotate your camera such that the underside is facing you and the lens is facing the ground.
    • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
  2. Sony Handycam HDR-CX380 Camera Shell Replacement: 2 단계, 이미지 1/1
    • Using your left thumb, push down the slider to the left of the SD card slot.
    • When inserting a new battery or reinserting the one you removed, you can ignore this step.
  3. Sony Handycam HDR-CX380 Camera Shell Replacement: 3 단계, 이미지 1/2 Sony Handycam HDR-CX380 Camera Shell Replacement: 3 단계, 이미지 2/2
    • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
  4. Sony Handycam HDR-CX380 Camera Shell Replacement, Camera Shell: 4 단계, 이미지 1/1
    • Orient the camera with the battery side facing up.
  5. Sony Handycam HDR-CX380 Camera Shell Replacement: 5 단계, 이미지 1/1
    • Remove the single 4.5 mm Phillips #00 screw.
    • Remove the single 5.5 mm Phillips #00 screw.
  6. Sony Handycam HDR-CX380 Camera Shell Replacement: 6 단계, 이미지 1/2 Sony Handycam HDR-CX380 Camera Shell Replacement: 6 단계, 이미지 2/2
    • With the blue plastic opening tools, gently pry the plastic casing surrounding the start/stop button free.
    • Remove the casing using your right thumb and index finger.
  7. Sony Handycam HDR-CX380 Camera Shell Replacement: 7 단계, 이미지 1/1
    • Flip open the LCD panel to get to the side panel.
    • Remove the three 5.5 mm Phillips #00 screws.
  8. Sony Handycam HDR-CX380 Camera Shell Replacement: 8 단계, 이미지 1/1
    • Turn the camera around to the grip side and remove the 5.5 mm Phillips Head screw using your J00 Phillips Head screwdriver.
  9. Sony Handycam HDR-CX380 Camera Shell Replacement: 9 단계, 이미지 1/1
    • With the bottom of the camera facing up, remove the two 5.5mm Phillips #00 screws.
  10. Sony Handycam HDR-CX380 Camera Shell Replacement: 10 단계, 이미지 1/2 Sony Handycam HDR-CX380 Camera Shell Replacement: 10 단계, 이미지 2/2
    • Orient the camera so the bottom is facing you.
    • Use the blue plastic opening tools to gently ease the camera shell off of the camera.
    • Rotate the camera so the LCD side panel is facing you and gently pry the shell off from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zackary Williams
회원 가입일: 02/04/16
457 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-5, Blackwell Winter 2016 USF Tampa, Team 16-5, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G5
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 311
